The finish is awesome and matches the stock CF parts. The fit is not perfect though it is not noticeable and the bolt holes to hold the voltage regulator inside the right side scoop were of the wrong size. I went to ACE Hardware and bought size 5M bolts.
I left off the lower left hose cover as it is not needed after you remove/hide all the hoses it hides, and zip tied the two braided oil lines together so they will not rub on each other.
Also, check where your clutch hose rubs against the left side engine case, mine has scratched the finish so I covered parts of the hose with clear plastic hose wrap.
