Ok, I thought, this won't be so bad...shee-yeah...right! :rolleyes:
I took the cans off my S4Rs and drilled the rivets on the inlet side out of the first one. The strap "sproinged" off and I thought "this is easy"...wrong.
The end cap refuses to separate from the sleeve. :confused:
I did what I usually do, which is come back to the forums searching for answers. I tried to use a plastic hammer to persuade the cap to come off and the only thing I managed was to put a couple of dents in the cap! :mad:
I toyed with the idea of just riveting the strap back on, but I now have a rattle caused by the drilled rivet ends inside the can!!
Can anyone offer suggestions on what I can do without inflicting more damage on my pipes???
Thanks,
Frank
Discussion Starter · #2 ·
Ok, for the benefit of others, here's what I found out:
The cans were put together with a bead of sealant as well as the rivets at each end of the sleeve.
I used a narrow, flexible putty knife to get betwen the sleeve and inlet cap to cut through the sealant.
Once I did that, the inlet cap popped right off. I don't know about other cans, but that's how the Arrows were done. Anyway, mission accomplished. :cool:
All the Best,
Frank
