This idea intrigues me the most. Are you saying the rear tire can remain on the ground? And how do you know how far to wind the jack out?Ddan said:Alternatively, you can support the frame using a small scissor jack on top of the rear tire, or something similar.
The tire can remain on the ground. I find it easier to manipulate the tire/swingarrm to line things up. You can do the same with the jack.Wanwo said:This idea intrigues me the most. Are you saying the rear tire can remain on the ground? And how do you know how far to wind the jack out?
Yes, the tire can stay on the ground, but a rear stand makes it easier. You only need to wind the jack until the weight is off the shock. Loosen the nut on the shock, turn the jack until you can wiggle the bolt.Wanwo said:This idea intrigues me the most. Are you saying the rear tire can remain on the ground? And how do you know how far to wind the jack out?
Yep, thats how I've done it - I put a block of wood across the bottom of the passenger grab rails and put a jack between the top of the tire and the block of wood, then wound the jack up till the spring felt mostly unloaded - I then loosened of the bolts holding the shock, and sort of jiggled the jack till the bolts could slide out. I actually had it up on a rear stand rather than with the wheel on the ground, but having done it like that before, I'd happily do it on the sidestand and wheel if I had to...Wanwo said:This idea intrigues me the most. Are you saying the rear tire can remain on the ground? And how do you know how far to wind the jack out?
Yeah, I'd back it off a little till the tire isn't obviously deforming, then remove the nuts and adjust the jack by hand until the bolts come loose. (Note, I've got the old hoop-style rear suspension, but I'm reasonably sure this approach will work with the "new" suspension too.)Wanwo said:You can see in the second pic, the jack is starting to compress the tire. So is this probably too much?
Don't you need a press to get the spring on and off?Wanwo said:Thx for the replys. I have a lot more confidence about it now. I'm removing it because I want to paint the spring and finally get rid of that awful yellow.
So my next question is are there anyone with tips on painting the spring? Can I just rattle can it?
NoArchimedes said:Don't you need a press to get the spring on and off?
Removing the shock is actually not that big a deal, I suspect I spent almost as much time explaining it to him as it'll take him to do it...VermontDuc said:In my opinion, I can't see going through all of this to paint your spring
PM SydMonster his featured bike has a painted rear spring, I'm pretty sure it's the same House Of Color red as the rest of the bike, and I think it's holding up just fine...and I doubt you will be able to keep the paint from cracking and peeling off.
