·Hi Guys,
Need a little advice here.
Got a '95 M900 with 33,000 kms on the clock. Last service at 30K kms the shop said they'd checked my service history and decided my valves didn't need checking (...?!!!).
Anyhow, on Sunday I decided to check the valve clearances (inlet openers 0.05mm and 0.08mm,exh openers both 0.08mm,inlet closers 0.1mm and 0.04mm, exh closers 0.07mm and 0.02mm)
. These seem out of spec compared with the manual, however what intrigued me was I set the cambelt timing marks to the little blips on the covers (and also on the crank body mark) and had a look in the timing window on the left hand cover....no little timing marks in site !!! ???
I thought I would see at least one set of timing marks here, if all is correct ? (It should align with the horizontal cylinder TDC timing marks shouldn't it ?).
Any suggestions as to what may be amiss, or whether I'm doing something wrong here'd be appreciated ! :-/
Thanks guys,
....Simon
Thanks guys,
....Simon
