Its called 'Profi Dry Lube... I used it back home in England.
The following is from the only site I have found that supplies it here......
http://www.triketrails.com/profi.htm
PROFI DRY LUBE dry PTFE chain care produces a completely oil and grease-free seal. The microparticles are firmly pressed onto the chain whilst in motion and cannot be spun or washed off.
Regular use guarantees above-average life of the chain, always clean parts. The chain has to be cleaned once before the first application. (O, X and quad-ring chains on soap basis).
Chains lubricated with PROFI DRY LUBE do not attract or bind dirt, so there is no 'fling', meaning the rear wheel always stays clean.
PROFI DRY LUBE was developed in 1995, researched and tested extensively in the laboratory in collaboration with motorcycle specialists.
After about 600km, the grease applied at the factory to the chain is generally driven off. PROFI DRY LUBE can then be used immediately.
Chains which have already been treated with conventional, sticky chain sprays must first be cleaned. The chain should not have been in use for more than approx. 10,000 km. This guarantees that the sealing rings are still functioning.
Optimum chain care is achieved through economic but regular subsequent treatment. PROFI DRY LUBE can be applied every 400 to 500 km and after travelling in the rain (prevents rust film). One 380 ml can lasts for literally thousands of kilometres.
1 866 587-4537
Its NOT cheap, but lasts for ages...I had 1 can for 12,000+ miles ;D
