Can anyone recommend a source for a broken shoulder bolt on the kick stand? Also the little 'loops' that the spring/s connect to? I just got this bike a month ago, going over what I thought was every nut/bolt. I almost laughed when of all things, the kick stand bolt was broken!?
Strange thing to keep you from riding...
The part # on that small plate is 82912602A $5.78, and main kick stand bolt, they call it "pin" is 82111032A $39.07, the nut is 75010481A $3.14, the other screw is M10X25 size, part # 77110481A $1.31, thrust washer is 10.5X16X1.8 MM part # 85212141A $0.61
Hope this helps :)
Discussion Starter #6
Thanks guys for the info guys. I've been using the DucatiOmaha site to find the part #'s.
As short Circuit is showing several of them.
The Plate is broken ($5.78 part)
The shoulder bolt is broken ($39.07) (got one coming from Ebay for $19.)
The nut is missing ($3.14) but I figured I can get one from the local hardware store once the shoulder bolt arrives. It's that little plate that frustrates me. That exact part is used on over 70 different bikes that Ducati makes. I was hoping someone would have one. My next step is to go to a local motorcycle salvage... They usually have tons of parts.
