I recently acquired used "996 style" master cylinders. The clutch master cylinder is in need of a few "minor" parts, but I can't seem to locate them. I checked Yoyodyne, but just got confused...and there's no email link to ask questions, so I figured that someone here might be able to help me out.
The clutch master is, as per Yoyodyne's terminology, a "996 style", 13mm, (P/N 10.6940.23)(http://www.yoyodyneti.com/detail.aspx?ID=244). I got this used off of an '01 M900 and the actual P/N stamped on it is 10.6939?
This master came w/out the pins to push on the piston and w/ a damaged piston dust boot (both pictured).
I'm looking for both, but can't locate any.
Yoyodyne sells 2 seal kits for a 13mm master, 110.4362.52(http://www.yoyodyneti.com/detail.aspx?ID=3841) and 110.4362.50(http://www.yoyodyneti.com/detail.aspx?ID=317). They both include what appears to be the needed dust boot, but I'm not sure. Also, I can't locate just the "t" pin(s) set-up that pushes on the piston. If anyone has extras of these parts that they're willing to part w/ for a reasonable $$$, and/or can help me decipher what's at Yoyodyne, and/or knows somewhere else I can get these, please let me know. Any help will be greatly appreciated. Thanks...also, i just realized I used a pic of the brake master cylinder, but the link is still correct (and it'll give you the general idea of the style)
