Allycat is right, even if your particular vehicle isn't covered, you can sometimes get around that. Remember that AAA covers the cardmember, not a specific vehicle, so if you already have AAA you will be covered as long as you have the plus coverage (which will get you 100 miles as opposed to 5 miles, and will cover motorcycles) Also FYI, you should tip the driver generously, it takes a lot more time and care to load and tow a motorcycle and AAA rates are on the low side, you trade off the low rates for quantity, although a AAA tow takes just as much time as a regular tow. If AAA doesn't cover a motorcycle in your area, there are other motor clubs that might, and also you should check on your regular insurance that you have on your motorcycle, a lot of times, towing coverage can be had for just a few dollars a month extra, the only problem with that is that you may have to pay for the service at the time, and get reimbursed by your insurance company, although in my experience it usually isn't too much of a hassle. Some insurance companies are better than others about reimbursement. Also, if it's an option, you can call different towing outfits, and check to see if they can direct bill your motorcycle insurance, that will save you the out of pocket expense. Again, you should have some kind of towing insurance on you motorcycle, because you are at a tow truck drivers mercy, they can charge you whatever they want to tow you, and a motorcycle usually has a premium attatched to it for towing. Sorry for being so long, I've just seen too many sad stories about towing (not from my former customers though ;D)
