I was wondering if I can bolt on new four piston calipers on my s2r 800 and still use the same disks and is this very expensive, I am sure the results would be very good. A link to a site with recommended calipers and or disks would be great.
Thanks again everyone great site. [thumbsup]
NO, as said by dukatea.
you need the 4 piston calipers (65mm spacing), can be found on most 2001-2005 ducatis. They are available in the gold finish and a couple different shades of gray.
can be had for $120-$275 on ebay.
you'll also need 320mm rotors. slightly used ones can be had for $100-$150 on ebay as well. the easy ones to find are stock take-offs the 748s. WARNING: the 749/999 rotors have a different offset and won't work.
before you upgrade the whole package, try a simple brake pad upgrade.
Q
Contact Ducman851 he's got what your looking for on the cheap. [thumbsup]
