·This may have been covered before, but I couldn't find it searching the forum...
My tail light goes out frequently (standard 1157). Usually a simple twist of the bulb fixes the problem, however it gets annoying removing the lens all the time (not to mention the bulb may lose the contacts if I hit a bump). Anyone have a good fix for this?
Also,
When going through my bulb twisting routine tonight I noticed that my front brake did not activate the bulb. The rear brake works fine. I recently had 12K service. Is there a contact or cable that the mechanic may have disconnected when working on the front brake?
Also,
