Hello,
I have just bought a Monster 620 2004 mod for my girlfriend and it seems to be a small problem with one or both discs. I have a spare set of discs for my Aprilia RSVR-01, and i wonder if they will fit on the monster. My plan is to take the discs of and try to loosen up the springs and the rings that hold the pi-cs together.
reg
Helge
The RSVR and the Duc use the same rotors, You may find that the Aprillia uses the thicker version, but they will still fit.
Thanks,
Symptoms: The front part is shaking when braking, had something similar on the RSVR, that why i have a spare set of discs. There i loosened the small springs and cleaned the rings and it turned out ok. But on the Duc it feels much stronger, so i'm afraid the discs are gone.
Helge
