I'm looking for a part number or a name of that bracket that goes between the rear axle nut and the swingarm. The bracket basically clamps down to the underside of the swingarm from the axle bolt to keep the nut from turning.
Is this a stand-alone part or is it somehow connected to the rest of the rear axle/swingarm assembly?
I've never actually removed it.
Stuart
Re: bracket thingy btween r axle nut & swingar
If you are talking about the plate with marks for rear wheel alignment - it's part # 374.1.012.1A
I think there are better aftermarket ones as stock ones bend the lip and scratch the swingarm quite easily when turning axle nuts
It is a stand-alone part - not attached to anything
let me know if you wanta stock on. Ducati finally got my part to me but I've installed a salvage adjuster and plate so I now have a spare.
