Get maximum performance from your bike with an air filter from BMC. The very same filters we use in our own racebikes and the same ones used by top teams in both domestic and international series, if it’s good enough for top teams, it’s good enough for your bike.
For most applications, BMC Air filters come in two flavors: Standard Street, which BMC designed to stand up to the rigors (read road debris) that comes with street riding or the Race Version which, for those of you that require maximum potential out of your motor, you may wish to choose.
Call TJ at 866-931-6644 ext 817 – or – send an email to FORUM at RIDERSDISCOUNT DOT com – and please let us know model and year your bike is so we can get you what you need fast.
All BMC filters come with everything you need for a quick, simple installation. If your application requires a foam gasket, it’s included with the filter.
BMC Race Filters have a distinctive yellow line passing through one side of the element.
At right is a BMC filter, at left, your standard OEM filter. Notice the larger space between weaves on the BMC device that allows air to pass through more freely.
BMC filters are usually lighter too, notice how narrow it is compared to the OEM filter it sits atop of.
