Hello all. I just bought a 14 ducati monster 796 ABS. The fluids look a bit dark and I would like to get them cleaned up. Problem is im not sure where to begin on this particular bike. Have a mityvac just need to know the process for doing it. If anyone has any advice it would be much appreciated. Thanks.
Typical procedure. Find bleed screw on caliper, loosen, then pour new fluid in as you suck out the old stuff. Check to see if any air got in and do a typical bleed procedure. Tighten it all up and you're good to go. The clutch takes the same fluid, so it might be a good idea to replace that at the same time.
Thank you. Rear brake reservoir is right next to it correct? Just want to be sure on the locations. And thank you again for the help.
