1 - 15 of 15 Posts
The clutch lever broke clean off. Anyone know how much one of those things costs? Finding prices on replacement parts is like pulling freakin teeth.
grr
Thats alot more than i thought. GRRRRRREAT.
Thank you very much.
OK! anybody know of an aftermarket clutch lever thats cheaper? im in somewhat of a financial bind right now.
i feel your pain.
the stock one is about as cheap as you'll get. the aftermarket ones are usually billet or race type and 2-3x more expensive.
i don't know that that gearchage lever was used on any other bikes either. good luck man.
Mine got bent but still worked although I replaced it anyways. You can have it. If you're interested I can check to make sure the mechanic returned it to me when he replaced it.
Discussion Starter · #12 ·
Im ready to use a pipe fastener and a screwdriver right now.. so a bent one wont be an issue. are you in southern california?
When I dropped mine, my (semi) local dealership had clutch and front brake levers laying around for $20 apiece. Might break even compared to ordering after you count shipping, plus you instantly get it.
Took me maybe 5 minutes tops to replace the lever too-VERY simple.
1 - 15 of 15 Posts
