AZMNSTR: Yes, that's the Scorpio alarm I have.
I bought:
- The base unit ($299) which is much smaller than a typical cigarette pack. Can be installed at ANY angle, anywhere, as the sensors in it are solid state. Includes the "mini PDA" type remote you see in their ads
- The battery backup option: no added wiring - internal to the main unit, and adds maybe $30. Keeps the alarm working even if someone knows how to disable your bike battery
- The proximity sensor option: adds a "zone alarm" that works really well and whose sensitivity is adjustable. Costs about $30 to add, and adds only one module of size approx 1/2" x 1" x 2" plus wiring harness
- The remote "kill" option, that allows you to disable the ignition circuit if someone has grabbed the bike or is in the process of trying to steal it. Adds about $30 and a another tiny module that is maybe 1/2" x 1" x 1.5" plus wiring leads.
Check out the Scorpio website for more details. The website even publishes the installation manual, so you can see firsthand before you buy how easy it is to install.
The base installation requires tapping into just 4 wires on your wiring harness going to the taillight area:
- Ground wire
- Taillight hot lead
- RH signal hot lead
- LH signal hot lead
This done very easily with the tapping connectors they provide (which are also waterproof). Only issue I had was that to actually snap the connectors shut, I had to use pliers gently, rather than just hand finger pressure. But once they snapped shut, they held like glue.
I found the right colored wires to tap into by using a magnifying glass (no kidding) to view the silly small wiring diagram that Ducati included in the back of the owner's manual. I'm sorry I cannot remember the colors, but if any of you send me a private email to
[email protected], I'll look it up for you when I get back into town (I still kept the install notes I made)
If you add the remote kill option, you need to find the black wire that runs from the ignition module to the battery negative terminal - I haven't had time yet to decipher the tiny wiring diagram to find it, so I have not yet added the kill function.
This is a super sophisticated design that was well executed. The remote functionality is nothing short of amazing. It already paid its way last weekend when my 3 week old bike was "approached" while I was in a restaurant, and it chirped and scared off someone. The remote in my pocket both vibrated and sounded its own remote alarm. It works up to 1/2 mile away.
The only negatives I have found so far are:
1. The display on the remote is a little faint and hard to read because of its low intensity and tiny graphics (they cram a LOT into a tiny unit!!)
2. MY wife gets irritated when she provokes it into its "warning chirps" mode as she walks by too close while taking out the weekly trash bin!
I installed my components under the seat. To ENSURE that there would be no presure on them from the seat, I removed the cover that covers the toolkit, but left the toolkit in there. Everything fits fine, and you can put on or take off the seat like normal.
I have been super impressed with the unit and would recommend it very highly.
And if anyone out there can tell me where to find that wire that runs from the ignition module to ground, you'd save me a lot of magnifying glass time!!
Jim G
