Ok, so I have spent a couple of days reading all the old posts about headlights, but wwith varying results. I have noticed while riding at night that unless there are no other cars around you can't even see my headlight on the road. I want something better, but like the look of the stock headlight, so just want a different bulb. I have read about the high wattage bulbs causing load problems and melting wires. What are people using as a bulb that is noticably better and with no problems? I don't want the blue look, but a more white light is a good thing. It may be that my headlight needs to be adjusted, but I don't think so, as on the desert roads at night the light is fine, in the city it is not.
So PIAA or Hella? +30? +50? 80 or 100 watt?
It looks like this is a pretty common question (FAQ.....hint, hint).
