Make a small investment for your battery’s life expectancy. Battery Tenders can save you money in the long run by keeping your bike’s battery at peak performance. They’re fool proof and will not deliver power to any battery until the device’s circuitry determines that polarity is correct, at which point it delivers a charging voltage. Even crossing the leads won’t harm you or the charging device as no power will be delivered. Each battery tender has a four-stage, chip-controlled voltage delivery process that goes from charging your battery to maintaining it in a steady state for months on end. It will not overheat or overcharge your battery and is safe to use on sealed, lead-calcium or flooded batteries.
Having to hunt for a new battery after a few months of storage can be down-right annoying … and potentially expensive. With a Battery Tender connected to your bike’s battery, you’ll have one less thing to worry about, especially when your bike comes out of prolonged storage.
$27.99 gets you a Battery Tender shipped anywhere in the lower 48 states. We don’t have these on the website just yet, so call TJ at 866.931.6644 ext 817 and let him help you keep your bike’s battery in tip-top shape. You can also email him: FORUM at RIDERSDISCOUNT dot COM is the address for expert service.
The Battery Tender Junior includes a quick-release kit so you can easily maintain your bike’s battery when you’re not riding it. Just connect it to your bike, plug it in and it takes care of itself.
