Battery not charging on Monster 2009
Anyone have experience with Monster battery not charging? If stator diagnosed as OK, regulator replaced, what are the other suspects?
SHORT
LONG
SHORT
- Battery starts at 12.3v and ends 3-4mile ride at 10.5v
- Motorcycle Mechanic (MM) voltage tested stator and OK
- MM recommended replace REGULATOR but battery still not charging
- Rotating through 2 different batteries and both end with low voltage
- Acid battery 18mths & 3 mths old
LONG
- Bike complete shut down at traffic stop and would not start again
- Had it towed
- Figured it was bad battery and bought Li-Ion battery but that died
- Went to mech shop for help and they helped me test with voltage meter
- Stator ruled out as OK and replaced regulator as likely culprit but battery still not charging and voltage reading in the 10s according to bike OSD
- Spark plugs replaced
- Never had issues with bike running until 3 months ago with the shut down
- Installed, pigtail for battery tenderer, front and rear cameras
- Using Noco GENIUS1 to charge batteries. Supports acid, AGM and Li-Ion
- YTX14H-BS 18mth old
- Caltric Agm Battery 3mth old
