4 weeks ago I took my bike into my local Ducati dealer. I got it back Saturday. The bike went in for its 6k service plus it was leaking oil ontop the engine (head-cylinder gasket). This was my "free" 6k maintenance and the bike is still under warrenty.
pre-ride inspection everything seemed ok. I rode it home from the service and found a few problems when I parked in the garage.
(1) improperly blead clutch - popping during clutch relase a few minutes into the ride.
(2) chain slack at around 38.5mm (instead of 20-25mm)
(3) the head-cylinder gasket leak is even worse now - oil all over the place - including rear wheel and pooling under the bike. I looked at the new gasket - is it normal to use some kind of white silicone looking stuff to help seal the gasket?
They said the adjusted the valves and performed the normal 6k maintenance. I'm quite pissed at this point! I'm not sure if I should allow them to make it "better" or take it to another Ducati dealer.
Also, is there a list of what gets done at your 6k maintenance? This is a 2001 monster 750 dark. Just my luck, I had planned to take the bike to North Carolina next weekend (leaving Thrusday) for some nice riding with friends.
Any thoughts / opinions?
