1 - 8 of 8 Posts
· Registered
if it is the pump (prolly is) an easy test is bypass the pump and see if it runs on gravity feed. also make sure the fuel c*ck operates. seems i have a faint memory some Polaris vehicle uses the same pump and offers a cheap rebuild kit.
From my invoice for the Pentagonal shaped fuel pump rebuild kit
Manufacturers Supply Co.
Dorchester Wisconsin 1-800-826-8563
Part Number 451457
Part: $5.99
Freight: $5.99
...(also make sure your fuel lines aren't getting kinked shut when you drop the tank down on the frame)
· Registered
I second MR's last note:
Check for kinked fuel lines. Older bike, hot weather... a hose can collapse resulting in the symptoms you've observed.
Did the '96 have a petc*ck? My '99 has a vacuum valve.
· Premium Member
I've had mine die a block and a half from home... twice..
Saturday I had replaced the timing belts and hadn't ridden it. Yesterday, I was leaving and it died. Took off the seat, raised the tank and started it.. Made sure fuel line/ vac lines weren't kinked and lowered the tank and secured it. Rode away and got a nice 100 miler in the country w/ my son on his Suzuki (poor college student, no Duc for him).
BTW, I'm thinking that the large plastic insulating foam thingie (that's a technical term right??) can go away and may be causing the pinched fuel or vacuum line..
1 - 8 of 8 Posts
