Twas a lazy Sunday afternoon. 37 celsius and too hot to go for a ride. I decided to install the newly arrived K&N crank case filter kit I recently recieved from TPO. While setting up I noticed this nasty little mess....
The cable is an earth from the battery. It is properly grounded on the engine case just above and behind the clutch. Unfurtunately the cable was in contact with the rear cylinder head and has burned off the protective clear coat on the engine in the spot shown.
Has anyone had this problem before? IUs there a way to patch it? Will it oxidize if left unattended???
Any advice most welcome.
