Hello all,
I am the owner of a 95 900SS-SP. I hope all you Monster owners will accept me and can help me out.
My bike sat idle for a couple of years due to an arm injury. Along the way the battery died, so the bike was not started and the carbs clogged up with residual gas :-[. Anyway, to make things right I replace the battery and pulled the carbs for cleaning. The electric fuel pump was replaced as well. At first I cleaned the carbs with spray cleaner and blew them out with compressed air. The bike started up ok, but ran rough above 3k rpm and backfired lightly when rev'ed. I pulled the carbs again and soaked them in liquid carb cleaner. The bike now seems to run fine on a brief ride, but still backfires lightly above 3k rpm. I have done all the checks in my manual for the ignition. replaced the plugs and wires. I have adjusted the float height. I have adjusted the fuel mixture screws from one end to the other. The bike has a stage 2 jet kit with K+N filter and D+D exhaust. I have adjusted the needle position both directions. The bike seems to run ritcher or leaner as I do so. I'm starting to think the Ignition is not advancing. how do I tell, or do any of you have any other suggestions. I'm sure I left something else out that I've tried, but that about covers it. Sorry for the long post, and Thanks in advance!
900SS-SP
900SS-SP
