Does anyone here run this setup as opposed to the full Arrow's? I am & I'm having trouble getting the clamps to seal on the S pipe connection to the collectors. I used the stock clamps as they looked beefier than the Arrow ones put maybe the Arrow's are better because they are continus & cover the whole pipe with no gap. Just not sure where to place them as the 3 groves on the S pipes are wider than the Arrow clamps & the stock clamps. Should they be towards the S pipe bend or at the point where the S pipe ends & the collector begins?
Tia [thumbsup]
I would lean towards the end of the pipe, leaving the gap on the pipe/muffler side of the clamp.
Worst case: try both.
Hope this helps....
Also, if there's only a little leaking, this is unfortunately considered "normal" on exhaust systems in general.
