I bought an used QD cat eliminator pipe from ebay..
it was a great price..
it was off of an 07 S4R
I installed it today..
but there's a problem
everything fits fine.. but I don't have "double walled" joints like in the pics
my pipes just slip over each other and that's it...
so when I tighten down the stock clamps..they don't do anything it can't squeeze the otter pipe enough to make them tight...
I don't know if i'm missing something from the kit.. or i'm supposed to cut slashes in mine?
or am I supposed to use those rubber lined clamps with the bolts??
pics on the website:
mine are just straight :( WTF
do I have an older generation of it?
I have the QD header pipe hooked up the termi cans. It's nice and tight with not much of a leak. What are you attaching to it? Stock cans? Giv a good dealer a call....the shops I deal with will help you with anything...good luck
I used the QD header because it was $400 cheaper then the termi. I put the termi cans on the QD and had no problems. I have an 06 s2r1000 with this pipe combo running for 3 years with nothing but good coming out of it. I dont know what type of cans your hooking up to but you might want to call a dealer. The two I deal with are ready to help with anything....good luck
Thanks for the reply
currently it's on Stock cans, until I source a decent priced set of used termi slip ons..
did ur pipes have the double walls? or single?
do u have any pics of ur joints where the lower end of the up pipes connect to the mid pipe
