1 - 11 of 11 Posts
Just finished up installing my 14/42 sprockets this weekend.
Holy balls.
I'm so much happier with this setup than with the stock 15/41 it had on it. I'm slipping the clutch maybe 65% less now and the engine feels happier all the time.
I also shortened the wheelbase, although it wasn't completely intentional. As I was cutting my new chain the 'perfect size' I measured happened to be on the wrong end of the link and I didn't realize that you can only cut one side of a link before I just barely started popping the rivet out.
So, to not compromise the integrity of the chain I went a half link shorter which put my wheel pretty much right to the edge in the swingarm, with maybe a couple mm of adjustment possible.
The result: now she falls into turns like none other. I like it.
The overall impression I get in terms of handling is that I have a smaller bike. In terms of power I haven't been able to really notice a difference yet because its been all rainy and wet but I'm sure she's quicker, and shifting is easier so that makes me quicker.
Raising the rear ride height is one of the best mods and the only free one I can think of. Other than that, the cheapest and best mod is the 14 tooth front sprocket. Makes a heck of a difference. I jacked mine up 1 inch in the rear and dropped the front almost 3/8 inch. BIG difference. It turns in and finishes the turn much better now.
And on bikes with the full termi kit (and the deep sump motor) a little extra ground clearance goes a long way.
Hey Aqua,
Any idea how this affects your gas mileage? I'd sure like to know how much it drops, if any...
I'll let you know once I get a data sample
I like the 14 tooth sprocket for starting out from a stop, puttering up my driveway and stop and go traffic but on the highway it seems like I'm turning the engine some pretty high revs at 75-80 mph. Luckily I'm on twisty two lane roads around here most of the time where I rarely get over 70.
My XT 600 turns lots less revs at the same speed and it has about the same redline.
If I put a lot of miles on the highway I'd go back to the stock 15 tooth.
Do you have a tach? If so what kind of rpms are you getting?
I noticed it was a little high too at around 80, but I didn't think too much of it. And what with the wind and all, I can't really hear the revs too well at that speed.
I can't decide...
although I am very temped to try a 14t. Slightly mixed on the idea as my Rs only gets about 100mi / tank already and my buds have to keep stoping for me to get more juice. On the other hand, 6th is very boggy until I hit 80 and get up above 4k rpm. so IF i could run in 6th more, it may be a wash.
I have a tach. I'm going on memory here but I think I'm turning 5500 at 75-80. Next time out I'll check and let you know.
Discussion Starter · #9 ·
Thats not bad at all, really.
Update on fuel economy: I've been around 130 miles if I remember the starting mileage right, and the fuel light is now flashing on and off. I think I got 90 miles or so on the last fillup, but I tried a different gas brand that time. This time I went with the regular Shell and I tried out premium just for kicks. So... I think the sprocket change doesn't affect economy that much, and compared to what gas you use, the difference disappears.
LA, any opinion on trading out just the front as opposed to front and rear(going to a 14/42), and have you talked to anyone on the rs with it? Just curious...Mike
my buds have to keep stopping for me to get more juice.
I don't think the 14t has altered my gas mileage much. I have had it for 5,000 miles now. You just change up the gears. I usually run mine pretty high on the rpms anyway, now I just get there quicker.
Oddly enough, out of necessity I have used regular gas (because there ain't no premium gas in some of the places I go), and I have found that I can get another 30 miles to the tank with regular gas and no noticeable change in performance on the S2R1000.
1 - 11 of 11 Posts
