I've got a small amount of oil leaking from the right side of the engine on my M696.
It could actually be from the base of the vertical cylinder. It's hard to tell. Bike went into winter storage with no leaks and develops this leak during the 1st ride of the season.
Any ideas as to the source? I'd like to get my dealer to look at common areas to cut down on the diagnosis time at the shop?
As much as I love my M696 I'm starting to get concerned about it's habbit of dribbling oil...
my 09 1100 also has an oil leak, dealer diagnosed & repaired, was comming from right side clutch housing, i know we have diff clutch but it was from inner housing, also found crack in top of gas tank, it is at dealer for last 15 days, part is on back order.
