·......were able to put humpty dumpty together again.
How is it faster?
Yellow dye has these electrons with high charge which makes its position more uncertain in regards to Schroedinger's equation. you can look it up on the net. In that u can subsititute the y component of the differential with the difference (delta) of charge between regular electron and yellow electron. As I said above it makes even harder to correctly identify the position of the electron. With these infinite number of yellow electrons on the monster this makes a compound effect of momentum on the whole bike and makes it move faster. Does that make sense???. I tried to explain the best I could...How is it faster?
No it doesnt work that way... When u mix all the colors yellow being the highest charged and white(and other colors) being the slowest the charges kinda gets cancelled off and gets a neutral color black... hence black is just "average" speed. white will be slowestSo, if you take all colors and combine them, would not that then be the fastest color, black? ;D
Why yes, my Duc is black.... 8)
