Has anyone tried just using foam in the stock velocity stacks instead of a regular rectangular filter?
Inquiring minds want to know.
The problem with foam is that over time it breaks down. It cracks and crumbles and gets into the engine. Not recommended long term and doesnt trap particals as well as K&N type filters.
CHeck the oil thread for some info on how well the K+N works.
If its negative I have no desire. Ive been using K&N filters on all my cars for over 15 yrs now, not once has one failed me. The only issues that come up are when people overoil them before they put them back in. If you do it properly you wont have any issues.
Ive seen several instances where, even if oiled correctly, the oil from the filter gets on the sensor wire on some hot wire type MAF sensors causing a drivability issue. Clean the sensor and it runs fine. (this is on cars BTW)
