1 - 19 of 19 Posts
Hi All,
Just purchased a new to me M696 with ABS this weekend. Curious if any current M696 owners have any advice or learned lessons that they can provide me? Do's, dont's, cheap recommend upgrades?
About me:
- Have had my M1 for 11 years but never owned a bike prior. Have only ridden a Rebel 250 prior (via MSF course 11 years ago) and a Ninja 250 (friends bike). Otherwise I'm a total novice.
- 30+ years old so not into show boating like I was in my early/mid 20's.
- Planning to only ride the bike in an empty parking lot and/or neighborhood side streets for the first 2 weeks to a month in order to get myself adequated with the bike/weight and throttle.
- I'm 5'10" about 220lbs sitting on the bike I could fully flat foot with knees very slightly bent (this is one of the key reasons I choose this model and the lower cc for a Ducati).
- My bike is bone stock with exception of a very badly done tail chop.
- I have full gear (armored jacket, gloves, boats, helmet)
If you plan on a lot of city riding, changing the front sprocket from a 15 tooth to a 14 tooth will make it easier to launch. A shop should be able to do it for around $100, or you could do it yourself for $20. Enjoy the bike!
Discussion Starter #4
Congrats on the bike. You might consider a refresher riding course.
Thank you. I'm going to skip on the refresher course for now. I remember everything verbatim and still have my study manual from the MSF course so I think I'm fine in that aspect. Time will tell though.
Do you have a link to a specific 14 tooth sprocket/brand that you would recommend? I've also read about a throttle tamer that really helps with launches, any input on if that is useful at all?
Part of me is of the mindset where I should learn to ride the bike as is/at it's most difficult so that I'm more prepped for the worst. The other part of me is like, I've read of people being scared from the pull of this bike a lower speeds so maybe I should just get the items recommended.
I may just tough it out and learn on it stock.
Discussion Starter #6 (Edited)
Three questions for you guys (or any current M696 owners)
1. See photo below, the dealer told me after I purchased the bike that it's an ABS model (I doubted them as it doesn't have the inner abs rotor but maybe I'm just an idiot. Can anyone tell from this photo if the bike is abs or non-abs.
2. Is the connector/cable below the tool bag in this photo the bike's OBD connector? Or am I off?
3. My bike has a horribly done fender chop by the previous owner it essentially has no license plate light at the moment so I can't drive at night legally. The wires I'm holding in my fingers, any idea if one of the two connectors could be the license plate adapter? If so, does anyone know what type of connector it's called? I'm trying to mod some license plate light bolts to use but first need to know the connector type I'll need to buy. Also, any idea why someone would put electrical tape over connectors
Final question for now regarding the the fast idle lever I've been turning on the bike with the lever fully engaged, however if I slowly bring it up to disengaged/off after 30-45 seconds I notice the bike will stall. Does any one know how long is good practice for the lever to be kept engaged? I live in LA 60-70 degree weather so am a bit baffled that I have to use it at all since I thought in theory it was only for cold starts.
Many thanks all!
Many thanks all!
newer owner as well here so my answers might not be 100% accurate.
1.) mines an ABS model as well, and your rear looks identical to mine minus missing the tone ring. that black wire is the ABS sensor line. another way to check is your guage cluster. at the top, the yellow light should be illuminated and says ABS as soon as you turn on the ignition and usually stays on until you get up to 5 mph-ish. scrolling through the A menu (pushing up on left hand controls menu button) should give you the option to disable ABS. that was my 100% telltale sign that mine has ABS.
for the missing tone ring, seems like it just gets bolted onto the rotor so should be an easy fix. ive attached a photo of mine.
2.) If I'm looking at this correctly, you have one connector, where I have three right there. from what I know, my connectors are for diagnostics and DDA. I think one of them might also be the factory ducati battery tender. from what i read, dealers install the universal sae battery tender connector since they knew no one would buy the factory tender. I wonder if there was some differences throughout the years. Mine is a MY2012. What year is yours?
3.) dont have any experience here. my fender eliminator comes in later this week so havent personally messed with any wiring in the rear yet.
4.) fast idle lever. im in orange county and actually use mine a bit. my bike wont stall without it engaged on a cold start, but runs pretty rough. i usually keep mine on for about 3-4 minutes and then take it easy for the first couple miles. i use the digital read out on the dash to modulate the lever. i try to keep my idle under 2k and above 1200 rpm. i will completely disengage the fast idle lever when my idle can stay above 1200.
to make it easy, i will turn the bike on before gearing up.
again, i am a newer owner so some of my information might be off. im sure other people will chime in and point you in the right direction
Discussion Starter #8 (Edited)
for the missing tone ring, seems like it just gets bolted onto the rotor so should be an easy fix. I've attached a photo of mine.
Thank you for the replies. Based on your photo, I think mine is not an ABS model. Your rear rotor has the notches on the inner panel which tells me yours is 100% abs. Regarding lights mine just has the 3 red rev limiter lights at the top of my LCD, no yellow light. That answers that question, not sure why my dealer thought it was ABS (probably just trying to up sell me even though I was already sold on the bike at that point lol) I think the wire you are seeing on mine is not for ABS but for the speedo guage sensor. I could be wrong though.
Regarding the connectors, I do have an SAE battery tender connector under my tank on resting on one of the frame spots. I believe this was installed by the original owner or the dealer I purchased it from. I'm assuming now that the connector I have is for the DDA in image #2. i.e ducati's version of OBD. That's my guess at this point.
I do have two other connectors wrapped in electrical tape as you can see in image #3. I'm assuming one is for my license plate light and the other is something else (not sure what) I'm just not sure why in the world any one would wrap a connector in electrical tape. Open wire I get, but a connector confuses me it's like a double negative. Still curious to know if anyone knows what type of connector type/cap I need to purchase to wire an aftermarket license plate light into it without spicing any wire. I.e. a plug and play wiring solution.
Regarding the idle lever, that info helps me tremendously! Thank you so much! 3-4 minutes seems like what I have been doing wrong. I only gave it 30-45 seconds prior. Going forward I'll attempt your RPM gauge/time recommendation and see if it helps.
I greatly appreciate your reply, even as a new rider, as it's pointed me in the right direction with some of these. Also as a side note it seems we live within 60 miles or so of each other. If you ever want to meet up and go for a ride or a coffee (maybe in a month or so when I've gotten more comfortable) message me! Btw mine is a 2011
Thank again!
Discussion Starter #9 (Edited)
I have one additional question in addition to what I already asked. My monster seems to have adjustable levers (They have a round cylinder on each of them with the numbers 1-4). Yet I don't see these mentioned anywhere in the manual. Here's a photo of what the levers look like on the clutch and brake side:
Is adjusting the lever distance on this bike as simple as rotating that cylinder to a different number or is that adjustment for something else? or would I need to unscrew something else?
And to adjust the gear change pedal's lock-nuts does anyone know the wrench sizes needed? The manual doesn't seat it but I'm guessing a 10mm?
Rotating the numbered dial should move the lever and adjust the reach of it. Should be enough difference to see when you rotate it.
Yes, the inner ring with the notches is for ABS. You should see on on the front wheel too, if it has abs.
Ride safe.
Discussion Starter #11
Ok so may have answered part of my own question here for #3. I think the taped connectors I have in my hand in the photo are in fact these:
Which I believe are both the license plate bracket wires which connector into the metal connection rods at the bottom of the OEM tail license plate bulb assembly here:
So if all of my suspicions are correct the last two things I need to know, which I'm having trouble finding is which wire is positive and negative (on the rear harness (black or yellow) I'm assuming black is negative but I'd love if anyone else has a more concrete answer. And last thing is does any one know if the wire connector type that I would need to purchase to fit in those slots in the first image above?
Thanks again for any and all answers.
My fender eliminator kit came in yesterday and I installed it so now I can accurately help out here.
You are correct. the yellow and black wires are the license plate lights. Yellow being positive, and black being negative.
I'm a little confused about your question. if youre asking what connectors are needed in order to keep the stock connectors pictured in place, I used a 1/4" male spade connector and it slide right in.
Discussion Starter #13
That's exactly the information I was looking for; 1/4" male spade connector!
Thank you so much. Now to order two of them, I hope they come with heat shrink wrap.
Discussion Starter #14 (Edited)
2 new questions.
1. is this wire the 02 sensor like I suspect? If so, shouldn't it be not this close to the muffler (due to possible melting???) Seems like it should be routed instead through the plastic cover on the left.
2. Is it normal for the plastic belt hosing/covers/base to warp after a while (see photo for misalignment) or should I chalk this up to a lazy mechanic. (see photo below) Should I be worried at all?
2 new questions.
here are some photos from my bike for the o2 sensor routing.
as for the covers, i would take them off and see if you can get it to sit flush and correctly. theyre just covers so it wont hurt the bike or anything if you take them off and put back on
Discussion Starter #16
Thank you so much for the reply. It looks my bike has a broken plastic hook to where the O2 sensor is suppose to be routed. Also, glad to see that your bike has the same foiling near the plastic as mine, I had thought mine was just modded/melted incorrectly.
Not a problem! Glad the photos helped!
I also have been putting in some thought about your fast idle lever and the fact it stalls. I dont think it should stall. does your bike have the charcoal canister removed?
I know people were reporting issues with start up and once that was removed, it works much better. Mine specifically wasnt having issues, except it being a complete eyesore, but id do some research into that to see if that would help.
Discussion Starter #18 (Edited)
Charcoal canister is still on mine. The only changes that I have seen from stock:
1. Horrible/cheaply done tail chop (still trying to wire license plate light bolts to make it street legal at night lol)
2. Broken 02 hose bracket
3. Misaligned belt covers (I think someone did a timing belt change in a hurry)
Everything else on the bike appears to be completely bone stock (even the tires are original, which isn't a good thing I know).
Waiting 2-3 minutes to gradually decrease rpm/fast idle seems to have solved the stall issue. Prior I was trying to do it all within 30 seconds to 1 minutes flat.
Discussion Starter #19 (Edited)
For anyone else wondering this is how the 02 sensor cable should be routed stock:
On mine the black tab that holds the wire in seems to have broke at some point. I'm now trying to figure out the name of that entire plastic piece or trying to reroute/zip tie it somewhere else. Unfortunately, I can't find any zip tie anchor points that will reach. I'd be open to plasti-welding a new tab (if that's even a thing, not sure lol).
1 - 19 of 19 Posts
