· Registered
Can a person add an adjustable fuel pressure regulator to a 02 Monster 750 to get more fuel in the mixture? Would a car regulator work just as well? What psi does the 02 750 run? TIA Later, Dan
· Registered
Re: djustable fuel pressure regulator?
That's what the "Modify" button on the upper right is for.. ;)
An adjustable fuel pressure regulator can allow you to do just that. I think Motowheels has 'em.
· Registered
Thanks, I just wasn't 100% sure if my car knowledge would apply to my Monster. Thanks for the "modify" tip too. I didn't notice it.
· Registered
Took me a minute to catch on???..you edited your first post.
I have no FHE on what you're doing, but my $.02:
A car regulator should work fine, my only caution is that they may be a higher flow capacity than what is necessary for a Monster, so it may act a little funny. They may also be physically large and thus tough to find a mounting spot.
IIRC, my S4 runs at 45psi. I don't have my service manual in hand, I'll try to remember to check tonight.
