I am a new Monster owner looking for a way to replace my stock non-adjustable forks for adjustable ones. I have found all sorts of varying info on what kind of forks can be swapped out but am still unsure about the best way to do this. Does anyone know if there are adjustable forks that will bolt right on to fit my S2R 800 without needing to bore out the top tripple, shim the bottom, etc.? In short, what is the best way to make this bike have adjustable forks?
- Taylor -
If you have the money, go ahead and send your forks to a suspension tuner, then you should get the full monty, forks and rear shock/spring.
If money on the short side, ST forks would be a 'quick' fix for your 'I want adjustability' issue...
Good luck.
