Borg Girl, good to see you back!
I've got the tall bars from CycleCat, they're a substantial improvement over the stock bars.
Absolutely gorgeous parts. They're about 3/4" higher, which is really nice since I'm 6'1" and grew up on dirt bikes.
You can independently adjust the position of the switches and the levers, as they don't have the locating pin for the levers.
For installation, it's helpful to have another set of hands to hold stuff. The switch housings are a little uncooperative at assembly. Once you've got 'em together, you don't dare let go to pick up the screws and screwdriver.
Make sure and carefully check clearance to the tank at full lock, I nearly pranged my tank. Adjust the steering stops as necessary.
