has anyone done this?? what do I need to get (does anyone make kits?) ? How much is this going to cost me?
Oh yeah one of those too [laugh]MNMONSTER750 said:caliper??
+1jswledhed said:Simple to do. Necessary, not at all. Steel braided brake lines, a Ferodo Axis rotor and the right pads will get you more stopping power than you can use and doesn't add any rotating or unsprung mass. 8)
A 2000 M750 should have 65mm calipers not 40mm.I didn't see a Caliper, but you will need one from an early Ducati with w/ 40mm spacing for the mounting holes(later bikes are like 65mm)
If that's the case, even better. There are more 65mm calipers out there than the 40mm. [thumbsup]mr. monduc said:A 2000 M750 should have 65mm calipers not 40mm.
The wheels are already drilled for the other rotor.howley said:Wouldn't you need a new front wheel too?
