1 - 11 of 11 Posts
The original clutch on my S4 finally gave it up at a little past 28k miles.
Symptoms were very grabby engagement accompanied by a 'squawk' heard and felt through the bike and lever.
Not surprising, considering the condition of the friction plates and basket:
That's about a 2mm gap.
Replaced with a Barnett basket and a set of stock plates.
Weighed a bunch of parts while I had the chance:
OEM steel basket : 38.6 oz
Barnett aluminum basket : 16.2 oz ( 1.4 lb reduction )
Set of 9 stock steel plates : 26.0 oz
Set of 7 stock steel frictions : 23.7 oz
OEM hub : 34.7 oz
Total weight, OEM : 123 oz
Total weight, OEM with Barnett basket : 100.6 oz ( 18% weight reduction )
Test ride tomorrow, I doubt I'll be able to detect the weight difference, but you never know.
Doesn`t steel friction plates wear out alu baskets very quickly?
Thx f weight info!
Barnett baskets have steel inserts, this basket wasn't brand new and you can see where the plates have worn the inserts a bit:
Aha, learnt something new today. Good second pic!
I replaced my old Barnett clutch pack (over 20K) with a new Barnett pack this summer. I still had the original ducati clutch pack (94 900M) and compared the weight....
The Barnett was 1lb 4 1/2 oz lighter then the original, 2lb verses 3lb 4 1/2 oz ....The new Barnett pack was even a few oz lighter then the old one??
Works great [thumbsup]
ducman851 said:
He got a heck of a deal ;)
Indeed, just very slightly used. ;D
I found the basket shown for $US 224 at Motostrano.
Not sure what the OEM plates run, CA Cycleworks has Barnett aluminum plate sets for $US 149.
Discussion Starter · #10 ·
I recall that Barnett claims that they can be replaced, but I'm not sure.
They're riveted on, so it's not a 'customer replaceable' deal.
1 - 11 of 11 Posts
