alright so i rejetted my carbs last night everything went fine until i had to adjust the mix screws. theres these brass plugs with little holes in the middle. i tried a little prying to get them out but i didnt want to get too crazy with it. any help would be appreciated.
all you have to do is get a drill bit ia liitle bigger than the hole in the plug. slowly drill in to the hole and the bit will grab and pull out the plug. let me know how it goes takes about 2 mins.
i was thinking about that. just wasnt sure if it was pressed in there solid or not. ill give it a try tomorrow.
