My clutch's freeplay fluctuates a lot. to the point of partially engaging the clutch. I've got the evoluzion slave cylinder. I've put a ton of fluid through it and am getting no air. I even cracked the master cylinder banjo bolt under pressure.
The problem worsens when i park the bike. It'll be fine when i go into a store or something, but when i come back out the clutch is engaged. (easily fixed thanks to the wrench in my pocket at all times). My only thoughts are that it is just getting too hot. The slave cylinder was very hot after just a 15 minute ride tonight. The clutch line runs right beside one of the cylinders.
What do I do? Any help would be appreciated.
