Up and back bar risers from Gen Mar
I look around for the best up and back bar risers for my 95 M-900. I found a set at Gen Mar. They had to make a slight modification but they are like 1 1/2" up and 1 7/8" back. They are great, but I still need to purchase a new set of break cables for the front break line. The fit is great on the rises, as it clears the tank like it was custom fit for it. I had to angle the handle bars slightly forwad until I get the new front break cable. I will see if I can get a picture up. If you want one you can call Gen Mar and ask them to fab one up. THey did not charge anything extra, because all they did was drill out two fo the hoels, and it oveled it out a bit on the front, but you cant tell.
