I just wanted to post this up because when i went searching for the location of the main fuse online i could find any pictures and the best advice i kept getting was to take my bike to the dealer and im not one to give in that easily.
The main fuse is located just behind the gas tank bushing on the throttle side of the bike once the tank fairings are off or just above the exhaust heat shield, you can likely get to this without all the dis assembly i did to find it. The PITA is getting the case to slide off its little mount so you can get to the fuses.
Sent from my SAMSUNG-SM-J320A using Tapatalk
