All of the above, they are completely different in every way. Sure you probably could somehow modify them, but you're better off spending the money on some marchesini's, that way you'll save some weight as well.
front axle diameter and wheel width is fine. problem with the front has to do with the 5-bolt-pattern rotors and the rotors themselves which have the blades at a different offset which then requires adaptors of some sort to move the calipers.
rear wheel's width should be ok but it's a 30mm axle, 5bolt pattern for the rotor.
