i'm mindfull of my neighbours when we set off on an early morning ride. besides, most drivers in D.C. are too busy talking on their cell 'phones or texting to worry about my termis.I don't think the bike is too loud without the baffles. You just have to be mindful of where you use full throttle. It's nowhere near as loud as a Harley with straight pipes.
Hold the display toggle switch up while you turn on the ignition, scroll to the display setting (same way you set the clock, for example) and change it to whatever language you want.Hi fellows,
I had a new Termi kit recently installed on my 696; ECU, air filter and silencers. The extra power is noticeable! great sound! Just one thing, the display shows the speed and the ODO in kilometers. I will appreciate your feedback.
Remove the screw from the bottom of the can with a hex key, I can't remember what size.Can any one tell me how to remove the db killers? I see a small hex nut, which is hard to get a wrench around. If I take the nut off, do they slip out?
