I am rebuilding a crashed 696 and have a problem. The bike is about done but when I started it it fired right up but jumped to 7000 rpms and stays there. The throttle is not stuck the choke is off and the butterflies are shut???? Help!!!!!!!!!!!!!!!!!!!!
sound like your throttle is stuck open. but since the butterflies are closed?
go back step by step on the rebuild.
what did you do?
how far did you tear it down?
any problems on the rebuild?
The bike was in an accident with front end damage, broken triple etc, no real mech damage, the wire harness was damaged so I purchased a used harness to replace, Ihas to remove the tank and air box to install the harness, I see no damage on the intake manifold, any other ideas? Is this something the computer could do? can it advance the trottle? Thanks
