I am rebuilding a crashed 696 and have a problem. The bike is about done but when I started it it fired right up but jumped to 7000 rpms and stays there. The throttle is not stuck the choke is off and the butterflies are shut???? Help!!!!!!!!!!!!!!!!!!!!
I am just pulling things outa my but here, but throttle position sensor? I can guess that you already checked the throttle cable all the way through from start to finish?
Ben
How shut are the butterflies? Check both, as neither of them should be more than 3 degrees open when against the stop screw.
Also, close the air bleeds.
same problem
I know this is an old thread but I've got what appears to be the same problem. How did you fix yours? Thanks
