Hey, guys,
I recently bought a 2007 Ducati Monster 695 Dark. It started and worked pretty nicely after I bought it and I went on a few rides. Worked beautifully, started up with no trouble. Yesterday, when I tried to take it out, though, I barely got it started and the engine died after a short idle. I then tried starting it a few times, way too many clearly since the battery ran down and it wouldn't start. Charged the battery back up, and I can get the starter to fire but the engine doesn't really catch. I've tried moving the cold start lever with really no effect except that it changes how long it takes before it gives up.
Here's how it sounds trying to start. Here's a checklist I've gone through just to eliminate some of the common causes:
1. Tried starting with kickstand down and in neutral
2. Tried starting with kickstand up and in neutral
3. Tried starting with kickstand up and in first, with the clutch fully engaged
4. Switched the battery out
5. Switched the spark plugs out
6. When I turn the ignition key to ON, I can hear the instrument panels whir and then I believe I can hear the fuel pump if I put my ear to the tank
And just to make sure I checked the basics:
Any ideas on anything I should try before I get this taken to a mechanic?
Here's a photo of the bike in happier times
- The bike has fuel. I can see it in the tank, but also I refilled it a couple of days ago.
- Ignition is ON
- Kill switch is set to Run
