Do these two bikes use the same front suspension? The dark has non-adjustable Marz - 43mm USD forks. I thought the S model had the same, but my factory repair manual has a picture that seems to indicate otherwise.
I ask because I was going to set up my dark with the recomended suspension settings for the S model (fork height and rear ride height) to have a good baseline for a more aggressive setup.
Thanks,
mike
The only differance between the two that I know of is that the S model has an adjustable rear ride postion. That is it. The forks should be the same, non-adjustable. But then again, I could be wrong.
