the link no work, but it's in the owners manual.
basically check everything but valve adjustments. Compression, oil pressure, bolt tightness, cable adustments, throtle body sync,
Check your manual, you should have an owners manual that you received with the bike.
I did my own, including compression and oil pressure. My bike has plenty of oil pressure, that's for sure.
