1 - 20 of 31 Posts
Hmmm- picked up my 44Tooth rear sprocket today and fitted it-vast improvement, whereas it would lift the front in first off the throttle under normal acceleration, it now does similar in second as well-still think it`s slightly overgeared so the 14T i allready have might find a new home tomorrow, what d`you reckon??
Go for it!!
A 14/44 will give you 135mph @ 9,000 should be enough to see off most on the twisty bits. But that also depends on how much you value your licence ;D
I'd be interested to know how your chain clearance is with this combination.
I ordered the 44T and will have it fitted at the 600 service.
Discussion Starter #7
They lost my 44tooth sprocket in a box in liverpool, they tried to re-order it but the reply came back-no stock,then the missing box turned up, looks like i might of had the last one..........-sorry about that!!-thanks for the gearing input
Mike,
Was the stock chain long enough for the 44T/15T. I am going to regear and needed to know if there is enough adjustment in the stock length chain.
Thanks,
Jeff
Discussion Starter #9
Yeah-straight on no problems at all, not even at the end of the adjustment,probably take a few more!!
Wouldn't a larger rear sprocket shorten the chain adjustment and a smaller front sprocket make it longer?
Discussion Starter #11
yep-sorry-misunderstanding here, i meant there is still more adjustment to make the chain shorter,ie it is still nowhere near it`s `minimum` adjustment,so you may get away with a 45 or even 46 tooth rear
What make of sprocket are you running? Is it hard anodized aluminum?
Discussion Starter #13
Straight out of the DP book,and yes it is hard anodised aluminium, apparantly the 916/996 adaptors will fit straight on, but it`s hard work trying to find a 44 tooth sprocket-yoyodyne list one in 525 width if DP are out of stock
R
So if you want to run a 44 tooth rear sprocket, do you have to go to a 525? Just wondering if I will be buying as chain and sprockets when I get around to this.
I do believe it is a 525 straight from the factory.
BTW, I'll be shipping your cans tomorrow, you should have them by Wednesday. Keep your eyes peeled for an Amsoil box.
R
Woooo hahahahahahahahh!!!!!!! Its in the 60's here. All my friends are out riding. I am sitting here with my wife. Its our anniversary. But if the bike was running, I would be out and meeet her for dinner someplace.
We'll it was cold and windy here in MA. I wasn't even tempted to ride...... I must be getting old......
Well, I did it. I ordered a STM quick change carrier, a 44T 520 STM sprocket and a DP 15T 520 along with a new DID ERV2 520 chain. I really have the sickness, DP wanted over $200 :mad: for their 44T so I decided to just go with the whole 520 set-up.
Jeff
Cool Finnster--- I'll be waiting for your "report" . This board is really a support group for mod sickness, eh ? ;)
1 - 20 of 31 Posts
