Hi everyone,
I recently just bought my 821 and I'm running into an issue where the bike is really hard to move in neutral and I can hear this clicking sound coming from the rear wheel specifically. I adjusted and lubed the chain to factory spec to make sure it wasn't the chain making the sounds and now my conclusion is I believe it's the rear wheel bearing.
Now my question is does anyone know the sizing, model number or something for the rear wheel bearing of a 2015 Monster 821? I even looked at All Balls bearings and they only list the "front bearing" so I'm wondering could both the front and rear be the same maybe?
I would really appreciate any help, thank you!
The bearings in the front are definitely not the same as the rear... haven't taken one out to measure yet...
And there's a lot of places in the rear assembly that can make those noises/ sensation....I'd pull the tire and spin a bearing with my fingers before I go looking for part numbers....could be just grime under the spacers
So I took a look and it is the bearing. The thing now is, I can't find any part number for bearings in the rear wheel. Don't see anything on the All Balls website either. Does anyone know how I can retrieve this info?
Appreciate any help!
Thank you so much!! This will help me tremendously. So I guess I can't get a bearings + seals kit from all balls racing. I'll have to order from this Euro site hey, for individual parts?
It's all stuff you should be able to get through your dealer but I recon someone in the US would probably have them all on hand.
With that many models using those bearings they shouldn't be hard to find.
