2013 Monster 796 wont start
396 Views 2 Replies 2 Participants Last post by  williamjr.ramirez
Hello, I hope someone can help. I have a 2013 796. I have changed `the fuel pump and fuel lines. It was doing fine but after I had to reattach a hose to the fuel pump it will not start. I turn the key, I hear the fuel pump prime, the starter turns over, and the plugs are getting spark. Any ideas?
Check your work, if it was going before you changed the fuel pump my guess is you've either got wires or hoses connected the wrong way around.
Thanks, turns out the history going from the fuel pump to the filter had a split in it. Replaced it with a better hose and now it's fine.
  • Like
Reactions: 3
