A couple of times recently I've noticed that my right indicator won't work - both the front and rear as well as the indicator light on the dash, however the Left works fine.
I know this is probably one of those issues that I could be chasing for a while - but it doesn't sound like a fuse if I'm not having any other electrical issues (although I could be wrong).
If I power the dash off/on once or twice then it will generally fire up after a while and start working again. But it is inconsistent and is annoying having to always double check that I'm actually indicating when turning across traffic.
Should I just replace the fuse? Or could it be water/dust that has gotten into the controls and caused the issue?
If anyone has seen anything similar please let me know!
